My 2012 800 Ranger will start and run for about 20 seconds and die, start again and die after another 15 to 20 seconds. I tested for voltage it's good, tested for continuity on pump it's good. But each time I turn the key on it sounds like the pump is laboring to run. After two starts the pump runs slow or not at all. I think it's a bad pump, any ideas? Thank You
It is .............new pump time..
Reactions: RJ
I looked this up and it doesn't list my pump oem number. Is it because its not the complete assembly?
ACHE, That is your pump . If you wqnt to spend more, search HIGHFLOWFUEL.COM for a assembly.
Discussion Starter #8
I went to Quantum website and ordered one from them that replaces my OEM number, the same price as amazon. Thank you for your help.
