Thunderhawk front & rear CV guards on an EV LSV: I installed a Highlifter Signature Series 2" Lift Kit (F&R), Outlaw DHT front axles and Highlifter Pro Series forward A-Arms.
Since I plow in the winter and do see some salt I decided to clear anodize all the aluminum parts.
The Thunderhawk guards are made for OEM axles and A-Arms. The aftermarket forward arms required drilling 2 additional holes so the rear brackets of the front guards would fit and match up, no big deal. I just attached the front brackets, marked the position of the rear brackets, removed, drilled and reinstalled.
The front Thunderhawk guards are pre drilled to use the 3 OEM guard fastening points AND additional pre drilled holes for aftermarket A-Arms we had to use the additional holes as seen from the front.
These offer the maximum protection front & rear and when going forward and in reverse. No clearance problems, bolted right on. Have drain holes. Occasionally collect debris but not bad (mostly grass)....just pick out with hand.
