1 - 8 of 8 Posts
Trying to find the cause for this grinding noise. Its very apparent when going down a hill.
I greased all zerks, replaced the belt.
Here’s a video on the noise
Does it make the noise when coasting downhill in neutral with the engine off?
I don't really hear a grinding myself. It's like something is loose and rattling. Nice video...
Same here. Perhaps a baffle in the muffler is loose.
Definitely sounds like it's comming from the rear, sounds like maybe your belt is starting to shred..
Original post states he replaced the belt.
Reactions: catmanLE
Drain the rear transaxle. Inspect the drain plug for unusual Mark's. And stick your finger up in the drain hole and see if you can feel the reverse chain slopping around. Shine a light and see if it's dragging on the case. Possibly a stretched out chain dragging. Hard to tell over the net. But it does happen.
Reactions: catmanLE
1 - 8 of 8 Posts
