hard starting
Tags
valves
1 reading
12K views 15 replies 6 participants last post by  BPS
2008 Ranger 500 EFI
Sometimes it is very hard to turn over. Like the battery or stater is poor. other times it is good. New battery and starter and everything checks on. Also it seems to flutter and sort of back fire at times and occasionally stalls at idle. Is this indicative of the valves needing to be adjusted?
Hour meter shows 1200 hours and I have no idea when or if the valves were ever adjusted.
Thank you in advance
#3 ·
The hard to turn over issue is most likely a groove has worn on the exhaust rocker arm where the decompression ball makes contact. With that groove the decompressor is basically non functioning. It is intermittent depending on what stroke, exhaust or compression, the engine ends up when the ignition is turned off.
The stalling and backfire through the intake is most likely a valve lash issue.
#4 · (Edited)
PC, Jungle and BPS, This sounds like what our '03 Ranger 500 4x4(carb) is doing, too. Acquired used with little background history in early Jan, '22 and has had this problem since. I pull the spark plug and cycle the engine with starter and replace the plug and it usually turns over and starts or a least gives an opportunity to start. The next time the start is attempted it "seizes" and a fresh batt. will not turn the engine over. I'm thinking the decompression system is faulty. Should I plan to replace the camshaft/decompressor and rocker arms? Can this be done (reasonably easily?) without removing the engine, altogether? When it starts and runs it seems to run well, no power issues or backfiring. Also, I think maybe a side issue is that it runs rich and initially fouled plugs with soot but has gotten better by changing out the fuel and trying to eliminate any water in the carb/ fuel tank. Air filter seems good/new. I have not yet replaced the inline fuel filter. (Many years ago, I was a motorcycle mechanic and raced motocross. This"seizing" reminded me of those big ol' BSA 500cc single 'crossers that used a compression release to "assist" starting.)
#6 ·
All you have to replace is the exhaust rocker arm if it has a significant groove worn in it. Yes, it is done with the engine in place. All that is required is removing the valve cover and rocker arm assembly. Make sure to check/adjust valve clearance upon reassembly.
#9 ·
I'd change the valve cover gasket, it'll be the only one affected. You'll want to get the engine rotated to top dead center (TDC) before removing/installing the rocker arm assembly and you'll need to have it set there for the valve clearance adjustment. The service manual outlines the procedure for this.
#10 · (Edited)
#12 ·
Pull your clutch cover and rotate the primary clutch.
#16 ·
Just wear or the exhaust rocker arm was not hardened enough to resist wear from the ball. It also looks like the rocker surface is plated, if so maybe the plating was not sufficient to combat wear from the ball.
