1 - 14 of 14 Posts
riding down trail rig shut down dead pulled fuel pump relay out and dash would light up towed back to truck winched on trailer dash blinking like low voltage
got home no power with key on . any ideas ?
checked voltage to buss bar power to d9 d7 b3 b7 constant vdc, ive tried hot battery, replaced relays ,fuses swaped ecm,new switch
problem seems to have something to do with orange wire from switch ? have diagram cant figure out were switch gets power?
voltage at switch 6 volts ? tried to hot wire orange wires under buss bar 2 lit up test light like they were ground , 1 turned fan on, 1 sparked didn't do a thing?
any ideas appreciated
ride safe
Discussion Starter · #7 ·
10-4 gonna grease all connections i gave up today and took it to a repair shop 1st time i coudnt fix my own problem.
ill keep you posted on findings i think it had something to do with chasy relay but i wasnt smart enough to figure it out.
when i put a test light on swiched power block under hood it was like it was ground instead of hot?
rocky mountain has manual for 90.00 dollars im gonna get one soon
ride safe
If you don't need a hard copy of the manual you can download one for $10 to $15 dollars. I have mine save to my Ipad and it makes it nice that you can zoom in on some of the photos or text. Plus you can wipe the glass of greasy fingerprints, can't really wipe the pages. Just save it also to a thumbdrive that way you will always have even if your computer / tablet fails and needs to be rebooted or replaced.
Discussion Starter · #9 ·
i went to service manual ware house 19.95 looks reptible gonna give it a try .thanks for the tip.
my son went and got my rig from shop today , tech found 3 bad wires were harness ys right below seat
didnt blow no fuses or relays ? even with a diagram i probably wouldn't of found it.
to all at prc stay healthy and ride safe
· Administrator
booger, yes...........
1 - 14 of 14 Posts
