1 - 3 of 3 Posts
I had the battery disconnected on my 07 XP this weekend and now can't get the clock reset. I followed the directions in the manual several times with no luck. I get it to the flashing 12:00 screen, but when I push the button again to advance thru the hours, it does advance the hours, it go to the next screen....help. Thanks, Mike
I guess thats not like the Big Ben alarm clock I used to use? Just pull out the stem and wind it until you get close! I quit using clocks when I retired from the Army in 92. Now I just punch the clock, work a couple of hours, the punch the clock again and go home.
Sorry, I couldn't resist.
Joe in Tucson
Hello Mike,
I just reset my clock today and ran into the same problem in the begining. I found that when the 12:00 starts to flash, wait about 5 sec until the 12 (hours) starts to flash. Set the hours then wait another 5 sec for the 00 (min) to flash. Set the min and wait another 5 sec to complete. That should do it.
Hope this helps, Good luck.
Rick in Goodyear
1 - 3 of 3 Posts
