From what I've read, this a pretty common occurrence. Probably not a problem if they go out in a minute or two after shutdown. If they are blinking also, you may want to check your connections and apply some dielectric grease while you are in there. If you do elect to do some troubleshooting, be aware that those lights operate from a switched ground, not a switched hot.
