Did this fix the problem willtim? I'm having the same problem with mine. Hoping to get it fixed without having to buy parts I don't need. Thanks in advance. Josh
A code 51 is an injector code......better check the fuel pressure.I replaced the IAC harness and now I'm replacing the tps harness. I just noticed that I'm getting the code 51 as well. I might just trade this in once I get these issues fixed for a new 900.
I'm trying to do this to mine. The screws on the IAC motor are trying to strip on me. I've stopped until I can get replacements. Local dealer is out of stock and so is fix my toys. Any idea what size and thread pitch these are? Hoping I can pick up some at the local hardware store.2 things.
Take off the IAC valve ... it's the one with 3 Phillips head screws on the passenger side of the throttle body, towards the top and rear of it. when you pull it out take some brake or carb cleaner and clean up the bore good, and the little plunger on the valve. the slightest amount of gunk will cause an air leak and a high idle.
Next remove the T bap ( in front of the throttle body in the rubber boot, held in with 1 bolt) sensor and clean the part that goes into the boot with some brake/carb/ electronics cleaner. these can get gunked up in time and give false readings.
Might be best to disattach the throttle body when doing this so you don't put too much cleaner down the intake to the engine. dont' want it injesting too much and bending a rod or something. I'd leave the throttle cable hooked up and clean the bore of the throttle body while you're there.
I bet it takes care of your problem, it did on my 2011.... and mine was doing it especially when cold and usually went away when fully warmed up, but not always. since I've cleaned the IAC, the problem left and hasn't come back.
