ok figure out exactly what u need
2~ 3/4 pipe couplings
2~2" PVC couplings
1~2" PVC think 12" the short piece at lowes only really need 8" tops
first off the pipe couplings are cast so the imperfections will needed to be filed down for a good flat surface
now cut ur PVC to fit best way to make a straight cut is to knock the PVC into the coupling "make sure its all the way in to the stop" also after marking it the best way to cut a good straight line is to make a bunch of cuts .. make a cut as in the pic an rotate the make a cut ect..
Next glue the PVC into the couplings dunno if every one dose this but it don't hurt
after that, cut them the best way to do this true is to cut to the longer side of the casting line in my case I don't now if all the coupling are the same but to the right of the nub pictured
two will be 1/16 longer pick two that match
that's it stacked with a SATV lift to get 4" total pretty happy with it an for CHEAP!
hope this helps Thanks RumRunner!
2~2" PVC couplings
