Home made tops.....post em' here. PLEASE
151K views 164 replies 79 participants last post by  thekennedycurse
Since tops seems to be one of the "must haves" for most on here, lets get a thread started on home mades. Try to post pictures, material, attachment method, cost and how it was made. This should be intresting.....................
#156 ·
500 crew, roof is 10g steel, box braked a 1"tall X for strength corner to corner, brake 1" drip rails full length, brake 6" sun visor @ 40deg. in front with drip rail, rear brake 60deg. 5" with 1"drip.
4ea. 5/16x2" U bolts hold it on with flanged lock nuts.
Camo paint job with local plants.
all the aluminum roofs I see have destroyed edges edge's from tree swipes, not mine it removes bark.
#158 ·
I'm a little embarrassed but sometimes all ya need is a little shade for you and your buddy. 2 pieces of 2" ABS some shade cloth and eye hooks to tie it down for the front and shade cloth stapled to a frame more eye hooks for the back. $10
Like
2012Ranger XP
I built mine very similar ,I used A Camo,Tarp,,The Feist Squirrel Dogs like it,,I have stuck A Tree a Limb ,thru mine ,A few times,,A needle A Piece of Fishing line,,no problem.
From the Signatures,,,
There some Traveling men here,,It's A Rough road when you travel from the West to the East,,Ain't Men,,,,LOL
#160 · (Edited)
1/8" aluminum diamond plate. I left it polished on top, and painted front, back and inside black. Also installed a headliner.
This post has been deleted
#165 ·
Man, I wonder if I can afford a top like that with all the money I saved on mine... 1/4" poly, bent with heat and patience, sealed up with 1/4" weather stripping and black caulk. Supported in the front with 1/4" "L" channel with 8 large rivets. I need to fill a couple bolt holes yet, but it's otherwise water tight and looks good enough for me.
Sent from my SM-G955U using Tapatalk
