1 - 7 of 7 Posts
I know this has been beat to death but I cannot find the post that talked about what type of material to make the flares out of. I am thinking of buying the sheet of plastic material cut to fit, heat it up to get the correct bend and screw it to my Thunderhawk Front blockers.
I bought black truck plastic mud flaps 24" X 36" cost me 15 buck each and are available in white also. E Z to cut and can bend them if needed. I put mine in my break and heated untill is was shinny black and sweating the bend and held till cool.
You can use ABS which is cheaper, but it's also a little on the brittle side. HDPE (1/8" thick) is my choice.
Reactions: fswan
Text Font Icon Smile
Ideal application for HDPE!
Discussion Starter · #6 ·
Where is the best place to purchase the HDPE? or where do you buy it from?
Because having it shipped would be expensive, you'll want to try to find it locally. Check yellow pages (or Google search) to see if you have a plastic supplier in your area.
1 - 7 of 7 Posts
