I cut a piece of 3"x5"x1/4" 6061 aluminum angle to 28". Measured and then drilled the holes. After I loctited and bolted the Rotopax mounts to the angle, I ground down the bolts so they're below the 3/8" thick rubber adhesive strip (to keep them from rubbing holes in the plastic bed). The 4" wide adhesive backed rubber step strips I got from the hardware store fit perfect. The 4gal Rotopax gas can is really secure with just the 2 lock and ride plugs. I was reefing on it pretty hard without it coming loose.
Not the cheapest mount ever, but I couldn't find anything that fit my needs.
