1 - 13 of 13 Posts
I done my own skid with 1/4 inch uhmw , had a helper to hold up and mount.
had a friend that used on his dumptrucks sold me a sheet cheap.
· Administrator
What kind of hardware did you use? Not a fan of running self tappers in.
I used the OEM polaris screws and cup washers, the same ones they use to attach the skid plate, they are a fine thread tapping screw. Much better than the coarse thread self tapping screws. And I also used the oem cup washers. The fine thread screws hold better in the thin wall tubeing than the coarse. And for a little extra thread engagement drill the hole smaller than the (polaris) screw, and it will push the metal to the inside of tubeing, or you can indent it with a punch.
Other sizes will work, but I recommend the 1/2 UHMW, the 1/2 allows you to recess the washers below the surface of the skid, possibly reducing broken screws and damaged frame holes.
Reactions: fswan
· Premium Member
Good advice (as usual!) from Greg. You'll probably need more washers and self tappers than you have. You can get the cup washers from a dealer (pn # 7556065) or from here; SSS OFF ROAD . They may have the screws as well--give them a call--or you may find them at a local hardware store or Fasenal, or McMaster Carr, or your dealer (pn # 7517386). Recess the washers using a Forstner bit. Flat washers would probably work as well but the cup washers protect the head of the screw from catching on stuff. For a little more peace of mind, you can put a dab of Locktite blue on the screws. Using through-bolts would be near impossible, or at least a royal pain!
1 - 13 of 13 Posts
