How to Add GPS Mount to Dashboard
1216 Views 3 Replies 3 Participants Last post by  HikerMitch
I'm a GPS lover and don't like to watch a screen 'jiggle' as I drive. This is my new '15 XP900 EPS.
Thought I would share a rock-solid solution for mounting a Ram-Mount "B" flange. Project time: 90 minutes.
Dashboard removed
Custom bracket to span the Ranger brackets that brace the center of the dash
I used a "C" channel type metal to help keep any flexing to a minimum.
View attachment 7965 The green Tie-Rap between the fender washers represents the factory Ranger bracket. I used 8-32x1.5" bolts with fender washers and Nyl-Lok nuts. (bracket is shown upside down)
Bracket installed. Now the alignment. The fitment of the bracket was a bit touchy and took 3-4 tries to emulate the angle of the dash cover before I got it just right. The goal was to touch the bottom of the plastic dash but not distort how it fits when you cinch down the Ram-Mount GPS flange.
Almost ready to mark the holes for the Ram-Mount after drill and tap for GPS flange mount.
With center radio/switch array removed, you can damn near climb into the dash to mark your drill holes.
Bracket final resting spot
Automotive exterior Hood Vehicle Trunk Bumper
Innocent looking. No unusual vibration.
Reactions: 1
the attachments do ....'0'.....nothing....
I mounted mine to the roof. Easier to look at, very stable and it's in the shade so no glare problems.
3/4" plywood roof is nice if you want to attach like walkie talkie, camera, mirrors, lights.... Also you can securely strap down some stuff on top.
Nice one Russ. My roof goes on/off based on the weather. On my '06 I had attached similar to yours but it was a killer looking into the 'sky' when the roof was off.
-Mitch
