1 - 7 of 7 Posts
I was wondering how do I check the error codes on my 2009 Ranger HD? I was riding tonight and the power steering starting going in and out, the speedometer started jumping up from my speed to like 40 mph and back. Plus, one of my headlights wouldn't stay on. Sounds like a short to me or may a fuse needs switching.
What do you think? Anyone else had this happen to them. I noticed it started doing it after I turned my HID dummy lights on along with my HID headlights. I did this all on one battery. After a few minutes of this, I got out turned my aux switch on to my other battery, didn't help. Maybe a fuse? maybe a short? When I find out to read error codes, will this show up?
Thanks in advance for all the advice.
You may have a ground/connection issue.
How to read blink codes.
Turn your ignition on and off three times, leaving it on the third time. It will blink 2 codes (example: 5 blinks = 5, and 1 blink = 1, to read 51)
2005 thru 2010 Ranger System Codes:
21: Loss Synchronization
22: TPS: Open or Short Circuit to Ground
22: TPS: Short Circuit to Battery
23: RAM Error: Defective ECU
25: Transmission Input: Invalid Gear
26: Vehicle Speed Sensor: Implausible
41: Intake Air Temp Sensor: Open or Short Circuit to =Sensor Voltage (ECU)
41: Intake Air Temp Sensor: Short Circuit to Ground
42: Engine Temperature Sensor Circuit: Short to Ground
42: Engine Temperature Sensor Circuit: Open or Short to Battery
45: Barometric Pressure Sensor: Circuit Low Input
46: Barometric Pressure Sensor: Circuit High Input
51: Injector 1: Open Load
51: Injector 1: Short Circuit to Ground
51: Injector 1: Short Circuit to Battery
52: Injector 2: Open Load
52: Injector 2: Short Circuit to Ground
52: Injector 3: Short Circuit to Battery
54: Engine Temperature Lamp: Open Load
54: Engine Temperature Lamp: Short Circuit to Ground
54: Engine Temperature Lamp: Short Circuit to Battery
55: Diagnostic Lamp: Open Load
55: Diagnostic Lamp: Short Circuit to Ground
55: Diagnostic Lamp: Short Circuit to Battery
56: Pump Relay: Open Load
56: Pump Relay: Short Circuit to Ground
56: Pump Relay: Short Circuit to Battery
58: Cooling Fan: Open Load
58: Cooling Fan: Short Circuit to Ground
58: Cooling Fan: Short Circuit to Battery
61: End of codes
That means...........NO CODES have been stored .
1 - 7 of 7 Posts
