1 - 9 of 9 Posts
Just finished this roof today on my 2015 Ranger Midsize 570 Crew. TOTAL COST about $185 and I think it is as good if not better then the majority of plastic one's available.
Here is what I used to build it.
1/4" ABS Black Plastic (bought a 4'x8' sheet from a local plastic distributor....$80)
Rubber coated Conduit Clamps 5 pk of 1 3/4" (Center Bar) and 10 pk of 2 1/2" (Sides) (Grainger $15)-I would use 2 1/4" instead of 2 1/2" next time because I had to cut them off about 1/4".
Stainless Steel Hardware (Nuts, Bolts, Washers)-Lowe's $65
Rubber Weather Strip 1" x 3/8"-Lowes $15
Krylon Fusion Black Satin Paint (2 cans $10 Walmart)
Step 1: Cut to the size you want. The roll cage is slotted on my machine so I cut to fit b/t the slots....it lays right in between once cut. I extended 7" on the front and 5" on the back. I used a circular saw to cut it....worked great.
Step 2: Place rubber weather strip on top of cage in various areas as a cushion b/t the roll cage and the plastic roof.
Step 3: Place all the Conduit clamps in areas to secure the roof. I did 4 on each side & 3 on the center bar.
Step 4: Drill and attach C-Clamps starting on the center bar then the right and left side. I used bolts, nuts and fender washers on the top with a rubber washer under for water proofing.
Step 5: Drill 4 holes on the front portion to attach to existing holes on front roll bar x member.
Step 6: I heated up the front of the roof with a heat gun and molded it to roll down as a sun visor. Be careful on this step because you can easly melt the plactic.
Step 7: Paint the top of the roof....Sunlight can degrade ABS overtime so a protective coating should be applied.
Turned out great and it is virtually bullet proof! Before I painted it my 160# son stood on top of it with little flex.......I guarantee it will not flap in the wind or blow off while trailering it at 70 mph.
Thanks for looking. Automotive exterior Vehicle Bumper Car Tire
Treadmill Automotive exterior Vehicle Car Exercise machine
Automotive exterior Vehicle Car Machine
Automotive exterior Car Vehicle
Pipe Auto part Muffler Automotive exterior Exhaust system
Automotive exterior
Very nicely done!:excitement::encouragement:
Very Nice and a great feeling to 'do it yourself'.....
· Premium Member
Looks great, nice work! I'm about 25 miles East of you, let's ride!
Nice job. A person can definitely come up w/ a "home made" roof that looks good & save quite a bit money while they're @ it. My plywood roof probably cost me half what you paid. ;-)
1 - 9 of 9 Posts
