It's not much of a crown but you can see it. Yes it's behind the axle nut. My old 800 has 2 cone washersI didn't look , but don't remember a crown, y'all are talking about the washer behind axle nut correct,
Nothing feels sloppy
All you need to do is take off the plastic center caps, remove the cotter pin and start the nut and then jack it up a bit and remove the nut check the washers and reinstall the washers nut , lower enough so the wheel does not spin or use a block or chock and torque the nuts and install pin and cap.You may not see any cone or crown to the old washers its hard to see.new ones you can see np.Guess I'll tear mine back down and look, cone faces in toward axle I guess?, All 4 axles like this?
No harm in that.I replace them because I want to, and I get mine for a little less then $8 per wheel. I doubt you could ever take the cone completely out of them, but maybe the reason hubs go to hell in a handbasket is not using new washers.....![]()
ok, good point.Mine has aftermarket wheels,you have to pull off wheels and tire
You are like me.I would have had to check to be sure also if had not have know.Well tore mine back down today, had 2 right and 2 on backwards, torqued everything according to book, back axles 110, front axles 70, lug nuts 100, maybe it won't fall apart😁, so much work in just greaseing bearings
I'm so bad about second guessing myself I have gotten to where I take pictures of things as I am putting back together no matter what it is. This way I can go back and reassure myself I did everything correctly. My wife says I have OCD whatever that is.It was tareing my nerves up🤣
