1 - 8 of 8 Posts
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Ranger Rover
Anybody find a great turn signal package with easy DIY install...any advice or ideas would be greatly appreciated.
If it were me I'd buy a package from JC Whitney or someone complete with controller. Just cut the and splice from there. If doing that seems troublesome go to a camper place and have them do the install for you, I wouldn't think it would cost that much.
Do a searhc and you should be able to find my thread that listed parts. Good Luck !
really easy to do ,
run a 2 core wire to each corner (1 red and 1 black)
bring them all to a waterproof junction unit like on lorrys
connect the 2 x left red together and the 2 x right red together
all black together
3 x wire to a 3 stage switch on dash then back to junction (on off on )
live from battery
earth on to the body then to the black
wire live to the switch
1 side of swictch to relay then to left indicater
otherside of switch to the relay then to the right indicater
if you want hazard warning ( all 4 corners flash) thats a nightmare
hope this helps you ,just doing this myself ,so I can put on the road as a car in england
What I did was order a simple signal tree mechanism designed for dune buggys. It straps onto the steering column.
I ran a couple of flexible motorcycle type lights for the fronts. I mounted them between up near where the roll cage bar passes through the front cowling where I could see them since I wouldn't be able to hear the clicking while motoring.
My first goal was to just blink the taillights but I could never get that to work right. I bought an inexpensive trailer light kit from Autozone and just ran new wires with new bulbs and drilled out the back of the taillights and added the additional lightbulb assemblies.
My blinkers work fine and I have emergency blinkers which a I run full time at night at the dunes for visibility.
I haven't found the best blinker module yet. The one I have blinks the lights faster than I would like which is part of its programming in case a light burns out, for some reason it is sensing a problem even thought there isn't one. If anyone has a blinker module that works good, please let me know.
There are no archives for turn signals when I search here...can anyone enlighten me??
Here you go:
http://www.prc-ranger.com/topic.asp?ARCHIVE=true&TOPIC_ID=4508&SearchTerms=turn,signal#top
To search for past articles and the archive section, go to www.prc-ranger.com and search there. That is our old server and there is still a ton of info located there.
1 - 8 of 8 Posts
