I got my K&N filter today RU-1770 that was mentioned right here on the great PRC and installed it tonight. The install was easy as pie. Unclamp the factory box and clamp on the new filter. The K&N has a 20 degree angle on it so if you put the tilt towards the firewall there is plenty of room for the storage bin. I also removed the stock filter from the air box.
I also decided to enlarge the holes in the exhaust gasket to allow for more air flow, also another good piece of information from the PRC. So after the filter install I disassembled the Y-pipe from the head. The exhaust gasket stayed on the head just like I wanted it to. However the the holes in the gasket on mine were exactly the same size as the ports in the head. I was hoping that it was a little bit smaller than the ports so I could open it up some to gain better flow. Anyhow no need to fire up the Dremel tool on my gasket. The picture isn't the greatest but you can see that holes in the gasket are the same size as the ports. Not the easiest place to take a picture. Maybe tomorrow evening I'll get a chance to take her for a spin and see if the new filter helped things a little bit.
I also installed two sets of those rubber spring spacers I picked up from Mike at Greenfield Motorsports today for my front springs. Another easy install. I jacked up the front end and popped them in. They should really reduce the front end squating especially when I've got the plow on.
