I bought this volt meter (back lit digital) on Amazon, $8 i think, and opened the box to find the back is fully exposed. I was hoping for a fully contained shell that I could mount on the dash with some double backed tape. As it is, I'd need to cut a hole just slightly smaller than 3"x 1.5" and press it in. It does have a retainer clip on the sides. I just don't want that big hole in the dash should this get wet and not work someday.
So, can I get some help creating a back cover, of some sort, that will only require a small hole for the wires to poke through, and bond to the dash? If all else fails, is there a goop type stuff to seal the board from moisture before installing?
