So to start out with I am clueless when it comes to mechanical issues but am willing to learn but I am trying to help my father with his 2007 Ranger 700 xp.
So there are a couple things going on.
Just prior to thanksgiving we installed a pair of snow trax. At this time the top speed was around 35-40 mph but was slower with a second adult in the vehicle to about 30 mph.
After installing the trax we started getting a smell of burning oil and it felt like we were loosing significant power there was a slight rattle I felt like there was something slipping and my mother reported that there was smoking in the vehicle cabin.
At this point I took off the side eqip. Box and looked at the belt. it appeared in really good shape. I did not see any ware areas and it appeared new. The clutch air intake was disconnected. I reattached it and hoped this was the cause.
Later it continued to worsen. So we pulled off the seat and discovered oil leaking from the air intake manifold boot and the oil breather gasket. we replaced both and leaks resolved. there is still a smell of burning oil but it might be residual. since then we removed the trax and the top speed is about 20 mph.
It seems we have lost significant compression.
I have checked the oil and it is reading high and smells slightly of gasoline and is honey colored. The air filter is clean and has no oil in the box. I will probably just drain the oil and refill but what should I look for to start fixing this problem its not easy to get it into the shop right now.
Do I need to get a compression gage and run though the process of testing compression of the engine or is there an air intake problem or am I in to deep and need to figure out a way to dig out the trailer so we can take it in.
Thank you
Thank you
