Thanks in advance for any advice, I have a 18' RZR 1000XP4. I have experience the following issues and believe them all to be related.
Ran for 2+ hours shut off and restart and acts flooded. But will start after cycling key several times to prime the fuel line. (No Code)
Ran for hour after that and stalled. Started right back up. (No Code)
Another time it ran great for 3 hours, then starts cutting out. Never died. (No Code)
I am leaning to TMAP pigtail but can't get it to replicate.
Anybody have same issue?
Craig, the obvious place to start is with the fuel pressure. Check the gas tank vent while you are at it.
A complete check of the fuel system is called for. It sounds to me like you got some bad fuel and the in tank filter is plugging up which could lead to other problems.
I'd check for spark the next time it happens. After 2 hours ignition coils can get pretty hot and coils tend to fail when hot. IT's an easy check and easy way to eliminate ignition as the problem.
