I know there are a ton of posts like this but I’m seeing conflicting info, particularly on whether 30” tires will fit without rubbing.
What is the consensus, 30” tires generally ok? I’m looking at Maxxis Rampage tires which are reportedly right on spec in terms of actual height.
And since I’ll be going from 9” wide tires in the front and 11” wide tires in the rear to 10” wide tires all the way around, should I stick with the stock 5x2 or go with 4x3 wheel offsets?
