Posted the bare wires and have advanced since that one. Still having trouble with it backfiring and bogging out at low rpm's Idle's OK, runs over 30 great. fixed the wires, checked tps setting (which seems to change a little) Had a wide variation in output reading when slowly adding throttle. Found the throttle end going into the throttle body was TOTALLY worn out. fixed that cleaned and checked the throttle body, set voltage and checked base voltage seemed to run great, BUT next day after2-3 hours running started all over again crapping out at low rpm's and backfiring. Checked voltage AGAIN :dread: this time engine was hot??? voltage ALL over the place again. NO CODES??? Has anybody ever had a TPS that was temperature sensitive??????? in the past have set cold and seemed to run fine right away but then changed later. I keep checking things and fixing things, but keep coming back to the TPS. According to our local dealer they sell 10-15 a year so it must be a fairly common problem. ANY insight would be appreciated. Had to order one out of Phoenix as the local has 3 on BO until 11-21??
