1 - 11 of 11 Posts
I am looking at the Moto MTC tires mounted on M12 wheel but have a few questions. Right now my rig is stock but I want to fill out the machine better with bigger tires. I noticed I can get the MTC in 26x9x14 on front and 26x11x14 on rear or choose the next option of 28x10x14 all around. First off will the 28" tires fit on a non lifted machine without rubbing? If the 28" does need a 2" lift to work would it still fit ithrough a normal garage door? Another thing that I am noticing is the stockers use a staggered with....25x10x12 (f) and 25x11x12 (r). It seems the MTC's are narrower. I don't want the new tires to look slimmer than what I already have or am I missing something!
As a general rule, 28's will not fit without a lift or forward a-arms. 2" lift will be cutting it close.. as Commander said, depends on the machine
Like they mentioned, depends on machine. I'm running 28x10x14 MTCs on MSA M20's on my Ranger XP900. No lift, and it rubs just a little on the front fenders, but not enough to worry about. And it also still fits in my garage, with plenty of room to spare. second pic has 2 flat tires, but you can tell, my Jeep is taller than the Ranger and both fit fine.
Land vehicle Vehicle All-terrain vehicle Motor vehicle Automotive tire
Land vehicle Vehicle Automotive tire Car Tire
It's a 570 full size.
If that's the case you should be able to run 28s if you can deal with a little rubbing..but with a lift and/or forward arms you will be fine
I run 28" MTC on mine as well without a lift and very little rub. After a few miles on the tires and you'll be in the clear
Discussion Starter · #8 ·
I am really debating on changing to a Roctane 27" tire so I can save some weight. This being said would you gave a side view of your machine running the 28's with no lift?
I just put the moto mtcs on mine 28x10x14 all the way around it rubbed just a little so I put on the super atv forward a arm kit ,wich was very easy with no lift and im very happy with it
1 - 11 of 11 Posts
