1 - 9 of 9 Posts
Any rangers built after March 6th 2007 will have the new motor mount part number of 3021936. The old number was 3110044 this is the one that had all the failures, and they used this one on everthing from 700xp to atvs for many years. Thanks Dale!
Is there a serial number break? How can you tell the manufacture date? Thanks for the info!
Your serial number on the machine will tell everything from date of build, plant it was built at, engine size, etc. You could check with a local dealer to see if your machine was built before or after March 6th 2007. Thanks Dale!
The VIN tag also shows the Manufacture date.
Great... I checked mine and the date is 2/26/07. I don't suppose Polaris is replacing these under warranty prior to blowing up a belt are they? Anyone know what the new mount costs from Polaris?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by DMF
Yep, mine was built about the same time. [:(]
1 - 9 of 9 Posts
