under warranty because you went deep good luck T&S
jag50, hopefully your engine escaped without any major damage. However, if it starts giving you trouble, please contact us here at nFLOW Remanufactured Engines. We completely reman many engines that have been sunk. Just give us a call at 812-402-8282 and ask for Nick if you need anything.went riding yesterday, was couple atv's and 4 sxs's....I was the lead. I was goin down a trail that I went down before, heck even a kid on a 250 went down the trail; however this time was going to be different. The trail was in an ATV park across street from my house and im in there every weekend. As we are going down the trail the deepest the water ever got was about top of my tires 26"s. As I begn to go thru another "puddle" i began to ease in and then the "water puddle" decided it wanted more of my new toy. My entire front end drops, like off a cliff, water was up to the stering wheel and covering the back seats. I turned her off and got out so I could help the wife and kids get out from the back seat. We quickly began to pull her out, however the 'water puddle" had a tree root preventing my toy from escaping. After breaking tree limbs and making a ramp between rear tires and tree root and about 5 of us pushing my toy escaaped the grasps of the "puddle". After checking the breather and everything else and noticed water didn't get deep enough I started her up. She started right up, as I began to turn her around she shut off. Lift the back seat and began checking fuses, since water was in there and the fuses are dry. Eventually we tow her back to the house and push her up n a trailer. Now she is spending the night and most likely the rest of the week at the dealer.
I took a long limb and stuck it in the "puddle" and it was over my waist in depth and was going deeper.
Sprayed ether and she started up but then would shut off, seemed like the fuel injection since fuel pump was coming on....so who knows... She is not even 2 months old and only has 26 hrs on her,hopefully its under warranty
Lift the drivers seat, and remove storage tray to expose the fuel tank. You will see a 5/16 clear tube going from the fuel pump to the seat base frame, that is your vent line for the fuel tank. It is just pushed inside the seat base frame.wheres the vent tube... and can this be fixed on the fly or does it have to go to dealer....in case it happens again
+1 agree,Personally, I would not take this to the dealer until all else failed, because you are very likely not going to like the outcome of that visit. I would do as recommended above, especially remove the plug and turn over the unit plus air blow out everything including the air box, then install a new plug. I would drain the oil and gasoline out and inspect them closely for signs of water before trying to start.
Greg, I've been seeing this suggested often and thank you for doing so again. I just printed it off on paper as a reminder to follow through. I am not familiar with "bellows" and how it would function differently from a lawnmower fuel filter. Which would be more effective?Lift the drivers seat, and remove storage tray to expose the fuel tank. You will see a 5/16 clear tube going from the fuel pump to the seat base frame, that is your vent line for the fuel tank. It is just pushed inside the seat base frame.
It's one of the first mods that needs to be done.
You have the fuel tank, front differential and the transmission, all three need the vent lines extended or bellows put on, to keep from ingesting water. Most people run them up inside the cab area. Some put filters (lawnmower fuel filters) on or loop them and make sure the ends are pointed downward, so as not to get water in them when washing the unit.
I'd have to consider the bellows to be more effective because they essentially make it a sealed system and there's NO WAY water or dust can get into them unless the bellow gets torn or the vent line gets cut.......Which would be more effective?
