1 - 7 of 7 Posts
can somebody get the dimensions of the bed if yall have a minute? top outside to outside, top inside to inside, bottom inside, front back. I hate to ask, but I got a brainstorm to upgrade the sound system. thinkin about building a box for my 12", and maybe adding more 6.5s or 6x9s. figure in a week and a half left at work I could draw something up.
I come up with 53 3/8" inside bottom, top outside very outmost measurment is 59" but there is a slight angle on top also. Inside top I got 53 3/4". Might be off as it was dark and hard to read bottom measurement.
Oops just realized this is mid-size thread. May be different.
I needed those measurements trippin thanks
Reactions: Trippin
I just measured my mid-size:
Outside to outside : 51" wide
Inside to inside : 46"
Bottom inside to inside : 44" flat on the bottom, 45" about 1/2" off the bottom (above the rounded seam where the side meets the bottom)
Front to back inside to inside 32"
Front to back inside to inside bottom : 31.5" flat on the bottom, 32" about 1/2" off the bottom (above rounded seam where the back meets the bottom)
**Note: don't forget the radius where the sides meet the back and the 45 degree angle supports between the tailgat and sides
Now that I have explained it clear as mud, feel free to ask for any clarification.
Discussion Starter · #6 ·
You are awesome! Just what I needed. Many thanks bud!
Reactions: Limo driver
not sure how your building your enclosure, but, keep in mind that the bottom of the box,(floor), does have a bit of a bow to it also...so if you are putting in crossmembers/dividers or a floor keep this in mind
Cheers
1 - 7 of 7 Posts
