I have a 2008 700 Ranger XP, Bought it from a friend low miles and hours. When you ride for awhile and I mean awhile say 2 hours or more it has a a slight miss in the throttle just off idle. It ldles fine, runs out fine, just has a spot thats seems to be bad. Now fast forward to today, I was running full throttle and now it started to have low power and would barely move. turned of back on, then fine, Did it again. Was going to check fuel [pressure during this but of course I cant duplicate it or make it do it again. I have found that if I wiggle the wires on the TPS at the throttle body, not at the connector it will low idle then die. Am I maybe looking at a bad TPS? I feel confident in that but have read so much stuff on these about TPS, TBAP, just seeing if anyone has had a similar problem? Any info or help would be appreciated. Thanks
