121 - 140 of 145 Posts
Reactions: Stroke250
Discussion Starter · #126 ·
Discussion Starter · #132 ·
Are you going to mount it on the bed or on the roof?
I would also recommend a full cover
Either the cab or the bed, but haven’t decided just yet. I need to do some checking on it today to see where I want to put it for sure. Thanks for the tip on the cover.
You're welcome, one more tip, you need to get a baby bungee cord because if you lay it down with the handle on the upside it's going to start jumping up and down making a lot of metal to metal noise while you're riding.
Discussion Starter · #137 ·
Noticed for a while now that there has been a whining noise which was most likely the one way bearing failing. Finished up installing Gilomen’s new Ranger Pro primary. Figured this was the better route vs dealing with the factory flaws. Fluids got changed as well.
Wheel Tire Vehicle Motor vehicle Automotive tire
Wheel Automotive tire Gas Vehicle Engineering
Automotive design Gas Machine Engineering Small appliance
Gas Engineering Machine Auto part Automotive wheel system
