Tom, I ended up doing new wheels with my tires. I did it mainly for looks and the additional offset. Im not familiar with the specific tires you are looking at, but you will gain a little off set with most aftermarket wheels which will give you more space to run a little bit of a wider tire. Without the greater offset I would have hit on the strut and tie rod end (or at least been uncomfortably close to hitting). From the many posts I have read I went with 12" wheels. I think the 14's look a cooler sometimes, but the 12's are less prone to pinch flats if you ever run on rocky terrain.
