I finally got finished fitting windshields for the new RZR cage. These fit the 2014 and up RZR1000 and the 2015 RZR900.
The rear was a little tricky at the bottom outside corners because the 4 mounting tabs on the cage's crossbar run perfectly vertical, but the cage is is angled in on the outside. I made a better fit by adding an extra bend in the outer corners. 8)
