1 - 20 of 67 Posts
It's been a year in the planning, pricing, variance getting, permit pulling, site prep etc. but finally have broken ground.
My dad proudly showing off his work.
Man thats going to be nice size!! I got afew more years before I get one built. As Rich mentioned, keep us updated! Nice to get some ideas!
The weather in the last couple of days has really slowed the progress and with the wind scheduled for tomorrow and the cold temps again on the way, I don't see the men showing up for another couple of days. Watching the Mennonites work is really amazing. This is only the second project I haven't done myself on this property and I'm glad I didn't tackle this one. What you see there is 3 days work with 4 guys. Next is roof and siding so the wind, cold and snow are not my friends.
That looks great!
Discussion Starter #12
Pictures will be coming. The weather here has been very uncooperative for the past week with 2 feet of snow and really cold temps and high winds. They are planning on being here Thursday with a large crew. The main building is 50x40 and there is a 50x16 lean to off the back. I was thinking of in floor heat but it is not a shop that will be used or heated every day so the amount of time required to heat the building that way just doesn't work well for me. I have access to all the firewood I'll ever need so my wood stove will provide all the free heat. Hopefully with the lifts in there, I won't be crawling on the concrete at all.
Thanks all for the compliments. Can't wait to see it finished.
SSW Moderator
Looks great. It sure must be cold working out there now.
Sent from my Samsung Note 3 using Tapatalk
Ok, I can understand that, but if you ever want to you only got 1 shot, go ahead and put the 1/2 PEX in the floor, the stuff use to be pricey but everyone carries it today. I know to many that after the fact have regretted it, besides the outside wood burners are set up perfectly for water heat. As a side note my insurance company made me remove my wood/coal/used oil burner, all open flame burners need to be 8ft off the floor in a shop, I argued to no avail.
Discussion Starter #15
Finally a break in the weather. Roof on today.
I have until spring to figure out if I am going to lay pex or not. I hate the idea of spending all that money on it then drilling a hole through it for one of the lifts. I will be placing styrofoam insulation under the concrete for insulation regardless of in floor heat or not.
That is just a fine looking shop in the works..
Drilling into it is always a concern but if you lay out your reinforcing wire right and use it for the grid you should be able to pinpoint each run. Rough calculations, 6 runs @ 300ft each is about $600 in tubing. I apologize for seeming pushy but like I said you only got 1 shot, what I really like about mine beside it's the most efficient system for heating large areas is when I bring in the snowmobiles or plow truck after a hard day by the next morning it's thawed and the floor is dry. Anyways you got a great looking shed, but I'll bet it's not big enough....:D
1 - 20 of 67 Posts
