1 - 8 of 8 Posts
And just a little more $$$$$ too.
Looks like cut super swampers to me.
28" weighs 31.7lbs. Is that considered heavy?
I don't think that is heavy.
Discussion Starter #7 (Edited)
Most run bighorns so here are the weight of them.
Bighorn ATV/UTV Tire Specs**
Tire Size____________Tread Depth32nds (Inches)_____________________Weight- Lbs.
25x8-12__________________28/32 (.87")_________________________23.6**
25x10-12_________________28/32 (.87")_________________________27.8**
26x9-12__________________25/32 (.78")_________________________25.2**
26x12-12_________________25/32 (.78")_________________________29.9
27x9-12__________________25/32 (.78")_________________________32.6
27x12-12_________________25/32 (.78")_________________________36.8
26x9-14__________________25/32 (.78")_________________________23.0**
26x11-14_________________25/32 (.78")_________________________27.8**
26x8-15__________________25/32 (.78")_________________________19.4
26x10-15_________________25/32 (.78")_________________________25.6
Maxxis Bighorn Radial 29x11R-14
Weight30.40 lbs
28x10x14 weighs 27.4lbs weighs 27.4lbs
29x9x14 bighorn at 26.4 lbs, the 29x11x14 at 30.4 lbs
28x10x14 STI Roctane XD which is 31.5lbs
Big Horn (white lettered original) radial 28x10x14 weighs 27.4lbs
Ihjhhhhhwhich is 31.5lb
28x10x1 ST Roctan which i
Discussion Starter #8
I have 28x10 x14 bighorns and they suck.never buy a bighorn bigger than a 27 x 12 x 12.the 28" and up x 14.
the belt,cap and casing are paper thin.never had a flat with bighorns until now,5 of them.you can not stand a 28x14 bighorn up with out a rim, it will collapse
As you can see the 27x9x12 weight is 32.6.the weight of the 28x10x14 is 27.4lbs,whats up with that.
that is why im looking for a new tire.I like the racktane xd 28x10x12,and now the
STI Chicane RX - 8 Ply, DOT Approved
or go back to the 27"x12 bighorn,they last forever.
1 - 8 of 8 Posts
