Moderator
6, check the CRANK POSITION SENSOR HARNESS for damage ...UNPLUG it and check inside....check for rub throughs on the entire harness.. It is never the coil on 700....
Reactions: yooper265
Is this the on connected to the stater
Moderator
LOL.......you better be sure because if the CPS & harness is good..........and the stator is good....and the ignition switch is good...then the ECU is probably bad.... Check and clean all the grounds.. Check the ECU connection ....
