I decided I wanted an oil pressure gauge for my 2015 Ranger 570 Full Size. Dash space is limited so I put it in a blank area to the left of the steering wheel. I used a gauge with a 1 1/2" diameter. Initially I tried a gauge that had a maximum 60 PSI reading but quickly learned that on this engine 60PSI isn't high enough. A 100 PSI maximum gauge seems to be good. It surprised me surprised that this engine generated oil pressure that high. Maybe it's due to the use of the hydraulic cam chain tensioner.
There is a 3/8 pipe plug on the back side of the oil filter housing which is used for testing purposes. I removed that plug and attached my pressure gauge line there, ran it through the tunnel where the radiator lines run and up behind the dash.
Since the 1 1/2" gauges don't come with any way to mount them to the dash I made an aluminum clamp which currently attaches to the back side of the dash with double faced tape. If that doesn't work over time I can add a couple of stainless screws from the front.
Following are pictures of the clamp, the gauge and the final installation. I hope this helps anyone else who has considered adding a gauge.
Picture 1: Clamp
Picture 2: Clamp with "stand in" gauge for testing fit. Clamp goes behind panel and is currently fastened with 3M double faced tape
Picture 3: Final Installation
Picture 1: Clamp
