2007 Ranger XP will have a slot in the dash beside The shift lever that is blocked off.
it should be easy to just mount the 08 hand brake but there is no bracket to attach it to.
The EZsteer kit is going to come with a bracket that will allow you to mount the 08 hand brake.
the Directions say to cut out the factory bracket that is there to allow clearance for the power steering so it has a relocation bracket to do this. Which just so happens to work with a 08 ranger ebrake handle.
Step one buy a EZsteer power steering kit.
Step two order a 2008 XP dash Ebrake handle.
you can use the same parking brake cable.
Motor vehicle Mode of transport Reflex camera Digital camera Sky
Check out my wicked winch switch placement, I can shift gears while I’m lowering raising my plow with the same hand while still steering with the other hand.
This is the bracket that interferes with the power steering that they tell you to cut out. 07 rangers won’t have this bracket.
Bumper Wood Finger Automotive exterior Gas
Tool Hand tool Bumper Auto part Fashion accessory
08 Ranger dash parking brake handle
