1 - 20 of 33 Posts
Wanted to share a little of what I have been working on lately. I am attempting to build a stereo system, on the cheap, for my 2017 midsize. I began by cutting out a template from some scrap foam core board. 1 Template.jpg
Looking good so far, keep the pics coming!
Since it is being made of thin plywood, I thought it would be best to make some cross braces to add some rigidity. 9 Top ribs.jpg 10 Top ribs.jpg 11 Top ribs.jpg
The next step will be to cut slots in the plywood base and glue the braces in place.
I cut slots into the plywood to insert the tabs of the braces. 16 Cab side.jpg
While I was at it, I cut a hole to mount an old amplifier I had laying around. 27 Mounts for amp.jpg
...and added boards to mount it to. Used lots of Gorilla Glue. 26 Began to glue.jpg
let us know the cost please including labor T&S
Discussion Starter #8
I boxed in the amplifier, and left the top open to prevent overheating. 32 Four speaker rings mounted.jpg
Also cut speaker rings for four 6.5" speakers and a 10" sub-woofer. 32 Four speaker rings mounted.jpg 33 All speaker rings.jpg
Like I said, doing this as cheaply as possible. So I used wood from an old cabinet to cut the speaker rings and used a router to round the edges.
After everything is glued and screwed into place, I can begin to start the fiberglassing (is that a word?) procedure.
Discussion Starter #10
Thanks for the input. I am planning on sealing each speaker, and the sub, separately from each other. There will not be any little crevices for critters to get into, at least in the speaker cavity.
Discussion Starter #11
Time for the post weekend update on my progress. I bought some cheap fleece material from WalMart and started to cover what will be the speaker enclosures. 34 Fleecing speaker rings.jpg
I know it looks pretty rough right now, but I will trim up the edges and smooth as best as possible. 37 Done fleecing the four rings.jpg
This is where it all got kind of bunched up. I will try and stitch this together to help smooth it out some. 38 Have to fix this.jpg
Discussion Starter #12
You can see here where I was able to stitch it up to try and smooth that bunched up area. 40 Sewed up where fleece was bunched.jpg
Even if it shows a little, the "bad" spots will be behind the A and B pillars, and hopefully out of sight.
Discussion Starter #13
The radio I bought from Walmart came with a tiny remote. I didn't want to chance losing it, so I cut out a slot in the radio mount... 43.jpg
...and made a little box out of some to the scrap plywood to hold it. 44 Made and mounted box for remote.jpg
I stitched up a little "bag" to attached to the inside of the box to help hold the remote in.
Discussion Starter #14
I wasn't sure of how I would wrap the radio and sub enclosures, so I just did the four speakers for now. 45.1.jpg
Left it out in the hot sun all day to dry, and not stink up the garage. 47.1.jpg
I got that toolbox on there as a weight to keep it from blowing over.
Discussion Starter #15
After everything had dried, I was able to begin wrapping the sub and radio areas. 48 Fleecing radio mount.jpg
Discussion Starter #16
To keep everything "fiberglassed", I cut and layed out some more fleece in the areas between the two sets of end speakers. 62.jpg
This shot show where I had to "clean" up the area in the back of the assembly for the mounting points. 63.jpg
I forgot to build in reliefs for the two center mounting points. So some modification was in order. I drilled through the fiberglass... 64.1 resized.jpg
Discussion Starter #17
Thank you. I'm doing this as cheaply as possible. So not a lot of research or design has gone into enclosure volume, etc.
I spent like $40.00 on the speakers and $20.00 on the radio from Walmart, lol.
These pics are rather large and taking forever to load. But, from what I can see..... Nice!
1 - 20 of 33 Posts
