in Limited Edition Colors Minneapolis, January 7, 2015 – As part of RZR’s continuing innovation and commitment to its enthusiasts, Polaris is announcing several new models featuring new paint schemes and graphics, and a new RZR XP 1000 EPS model with the first-ever Internal Bypass Shocks available on a side-by-side. The new RZR XP 1000 EPS FOX Edition is hands-down, the best performing suspension ever offered on a sport Side by Side, featuring highly-tuned FOX Podium® Internal Bypass Shocks, re-tuned coil-over springs, new front stabilizer bar and softer rear bar. The vehicle offers the next generation of suspension innovation that takes Razor Sharp Performance to a whole new level.
The new FOX Podium® Internal Bypass Shocks found on the RZR XP 1000 EPS FOX Edition generates highly-progressive damping that gives the vehicle a plush ride with all the bottom-out resistance expected from an ultra-performance off-road vehicle. The shocks have large diameter bodies (3 in/7.6 cm rear, 2.5 in/6.4 cm front), reservoirs and increased fluid capacity for dramatic improvements in heat dissipation, fade resistance and durability. The internal bypass technology offers more zones than a conventional shock for better tenability and performance for the smoothest ride available on a side-by-side and better handling over a wider range of terrain at any speed.
To complement the new shock package, Polaris outfitted the RZR XP 1000 EPS FOX Edition with redesigned coil-over springs. The progressive rate upper spring is a lighter-weight spring that absorbs small impacts while the stiffer, main spring maintains ground clearance and absorbs bigger impacts in rough terrain.
The RZR XP 1000 EPS FOX Edition also is the first RZR XP to feature a front sway bar and also has a redesigned rear sway bar with 25 percent less stiffness. Combined with the FOX Podium Internal Bypass Shocks, the sway bars dramatically decrease body roll and improve vehicle handling and comfort. Along with the new suspension package, the RZR XP 1000 EPS FOX Edition features Matte Turbo Silver paint, cut and sew seats, new graphics package, innovative 6-Point harnesses and the Polaris Interactive Digital Display which is an integrated, industry-leading LCD display and gauge with full-featured GPS, mapping capability and compass. The display also features integrated Bluetooth functionality and shows the speedometer, tachometer, dual trip meters, odometer and maintenance warnings along with a digital clock, and operating conditions including fuel level and diagnostics. The RZR XP 1000 EPS FOX Edition will be available in dealerships starting in February 2015.
Along with the new RZR XP 1000 EPS FOX Edition,Polaris also is announcing several other new models with new paint scheme and graphics which include the following:
2015 RZR® 570 EPS Black Pearl Additional features on this model include:
  • Electronic Power Steering
  • Engine Braking System (EBS)
  • TURF Mode
  • Sealed under hood storage
  • Maxxis Tires with Cast Aluminum Rims
  • High / Low beam headlights
  • Black Pearl paint
  • Custom graphics package
  • Custom cut & sew seats with RZR emblem
  • Color-matched painted front and rear suspension springs
2015 RZR® 900 EPS Trail Blue Fire
  • High Performance Close Ratio AWD
  • TURF Mode
  • Driver’s Side Seat Slider
  • Cast Aluminum Rims
  • Blue Fire paint
2015 RZR® 900 EPS Trail Gloss Nuclear Sunset
  • TURF Mode
  • Nuclear Sunset paint
2015 RZR® S 900 EPS Voodoo Blue
  • High Performance Steering Wheel
  • Voodoo Blue paint
2015 RZR® S 900 EPS Stealth Black
  • Stealth Black paint
2015 RZR® XP 1000 EPS Stealth Black
2015 RZR® XP 1000 EPS Orange Madness
  • Orange Madness paint
2015 RZR® XP 4 1000 EPS White Lightning (Monochrome)
  • White Lightning paint
All models will be available in dealerships starting in January.
