My 2018 Ranger loves these relays. Has anyone else had issues with them? So far I have replaced 6 out of the 7 relays. I have not had to replace any of the aftermarket ones I replaced them with. I carry 4 spares with me just in case.
I have monitored the voltage with an oscilloscope and tested the battery numerous times. I have external relays on all the accessories I have installed. I have never had a relay that I replaced fail. So i am not sure.There might be something going on with your Ranger. In the last six years (I see north of 100 Rangers/year) I've replaced two. And one was because the owner had a giant light bar powered by the accessory circuit and it melted the chassis relay.
No issues.My 2018 Ranger loves these relays. Has anyone else had issues with them? So far I have replaced 6 out of the 7 relays. I have not had to replace any of the aftermarket ones I replaced them with. I carry 4 spares with me just in case.
The failed relays have been intermittent for the most part. So I would make the assumption that it is the high current contacts. I did measure a failed one between terminals 1 & 2 and got 134 ohms.Curious if the coil or high current contacts are going on it. Are you aware of which portion of the relay gives up on you?
I have had to replace 6 out of the 7 now. 1 original to go.And is it always the same one or random circuits?
