Per: Dale from Bikeman Performance http://www.prcforum.com/topic.asp?TOPIC_ID=326
(Alnash, You are correct the belt deflection should be 1 1/8. yes it will shift better once the belt is worn. But until then you are hard on your belt, motor mounts. crankshaft and clutches and your shift linkage. Yes eventually it will get better but until then you are putting undue stress on these components. If your car with automatic transmission shifted this hard you would be concerned right?)
Need input:
Do we not use the SP belt ?
Is this belt doing the damage to the motor mount ?
Why is Dustin from Polaris of High Point selling this to us ?
Need input:
