power strip under hood
66K views 42 replies 21 participants last post by  Hankdiggity
Can someone tell me what the 3 studs on the accessory bar are for???? I got power at one when the key is on but nothing at the other two. Am I just supposed to jumper them together for added terminals or is one a ground and the third for ?????? I cant find any threads that give a clear answer and I trust you guys more than my dealer! Thanks
#39 ·
I pulled the floor board up in the cab to run the heavy black and red
wires from under front hood to the rear to the battery. I used the
blue flex conduit as it is more heat resistant
than the black flex. Just enough wire to hook red on battery and
black to the common group of black grounds near battery. Ranger 570
#41 ·
Thanks will check the floor board out
#42 ·
Howdy,
So I'm in the process of wiring in a blue sea fuse block. I've pulled all wires and tested most everything. Part way through the night my keyed hot terminal died. I've disassembled the front of the ranger looking for an inline factory fuse. Having no such luck. Disassembled the terminal and figure the orange wire coming from the factory 3 wire plug set up has to be the keyed hot into the terminal. Tested at the back of the key.. anyone point me in the right direction of an inline fuse, anyone had this problem? 2014 900xp
Thanks in advance.
Hank
