Recently purchased a 2014 900xp and the driver side power window did not work. I pulled the door pieces apart and it looks like the motor assembly is missing. The wiring harness is there but has nothing to plug into. Does anyone know the part number for the motor and/or little gearbox (at least it looks like a gearbox)?
Thanks in advance....I’ve been searching the internet for 3 days and can’t find anything.
Is the pass.window working? If so take that panel off and look for a P/N on that, it will give you a starting point.
Usually the part numbers are only a digit off L to R but not always
Reactions: Rangerwhit
Yup rbarre your right one number off and on back order till 10 august for 408 dollars lol
Good ! Glad you got it sorted
trick 2 see if you can find a mfg. name on it might be able to google it and find a lower cost replacement ( doesn't always work)
My guess it is either Japan or China manufactured
also there is FIXMYTOYS.COM a vendor on this forum may have discount for forum members
