I took my belt housing, in and outer, off to seal behind the clutches and when I reassembled the primary seems to be rubbing the outer cover at the top of the bulge that houses it. If I apply baby soft pressure upward with my hand to the bottom of the outer by the drain plug it stops. I took it all back apart, including removing the primary, like 3 times and it still does.
Any and all input appreciated fellas, thank you!
