1 - 19 of 19 Posts
I looking for the locking levers for pro fit windshields or part#
Chris
I need all of it. I'm wanting to diy a rear windshield/panel
I'm assumeing your doing a poly rear panel?
Just FYI, these parts will prob cost more, than the complete Polaris rear panel itself.
I figured that! I'm not sure what I was go to use yet and I wanted to see If could get the parts. Is there anything besides Polaris parts out there that works the same.
I do not know of anything off hand, but I'm sure there is.
Here is the cost per handle $21 ea.
I'm not trying to talk you out of it, and I will give you a parts list, but doing it this route IMO, is not feasible.
You will possibly have 3/4 of the cost of a complete rear window from Polaris, just in OEM hardware.
Not to hijack the thread but I'm looking for one lever and the two parts that affix to both sides of the windshield. I had a little whoops with one side.
Can you get these seprate?
Yes, you can.
Can you post a pic of what exactly that you need?
Yes, you can.
Will do. Thanks.
To the OP. Seizmik sells Pro-fit windshields now with a lever mechanism similar to the OEM. You may be able to get those parts separate for a DIY project.
Discussion Starter · #10 ·
Toxic, I completely understand and appreciate the information. I don't want build something I could've bought it for a little money.
Red rock, I seen that today I'll check with them.
I need: Qty 1 of A. Qty 2 of B
View attachment 14802 .
Can you flip the pieces in the pic and post that pic also.
I am working on it, may be later tonight or in the morning.
Are these parts for driver or passenger side.
Can you take a pic of the windshield and a close up of the handle assy, inside and out.
I have a component list, but Polaris does not have a diagram, it's making it hard to make sure I have the correct part number.
I have a component list, but Polaris does not have a diagram.
Piece A goes on the front of the windshield and should fit both left and right sides. It just holds the bolts.
Piece B goes on the back of the windshield where the handle mounts. Honestly I don't know which side the one in the picture is from. I lost one and broke this one (the little stop post broke). I would need pieces for both sides.
I'll post another pic tonight.
Thank you for your help!!!
A is Polaris part # 5439921 Handle Base, apprx $5 ea.
B is Polaris part # 5439922 Handle Spacer LH, apprx $4 ea.
Polaris part # 5450023 Handle Spacer RH, apprx $? ea.
It looks like they offer a complete set ( it does not say what is included in the kit).
Polaris part# 2205617 Service Kit- Clamp. apprx $26.99.
As I stated, there is no diagram with labeled part numbers on this windshield ( not sure why, and this is the first time I have encountered this).
So through my deductive reasoning process, I have come to the conclusion (99%), that the above part numbers are the correct ones that you need. If you need any further assistance, please ask.
I would still like to see some additional pics, when you have time.
Also, the part number may be molded into the part, it will be a 7 digit number in most cases.
Reactions: Redrock
I forgot to get pics but will try again tonight. Thanks again.
Here are pics of the Seizmik pieces from their Pro-fit folding windshield. Not sure if they sell these individually but if they do, they could be a good alternative to OEM. Especially the clamps if you want a fixed windshield or back panel.
Font
Pro fit roll cage
Anyone have a part # for these windshield clamps
1 - 19 of 19 Posts
