I am going to finish the project i started last weekend which got interrupted by a few obstacles including the need to buy a better switch and mount it properly vs the cheap toggle that i had. So, to clarify, i need to pop the top dash cover which is attached with push pins, then i can pull off the face plate for the switches so i can cut a new hole for the new switch?
I am assuming i will need to disconnect the existing switches to remove so i can cut with a straight edge razor knife. What about the two bolts on the dash that are used to secure the bottom of my windshield, do they need to be removed to get the top dash off?
Very happy to have been told about the power block under the hood. That will make powering up the light a breeze and since it is a small light, it will work great
