I have read every thread on this subject I can find on the topic and have followed the information provided. I still can not get my back up lights to come on while in reverse.
I have the 16mm bolt lights from Oznium.com mounted under the tail lights. I tried hooking them straight to the back up alarm wires and they did not work. I have tried wiring them to the back up alarm wires with a relay as a few of you have recommended and the still will not come on. I can plug them into the hot wire from alarm and a ground wire from the battery and they turn on, but they do not work if I use the negative (purple) wire from the alarm harness. I really want them only on as reverse lights. I do not want to wire them to a switch on the dash. I have a light mounted to the top for a rear work light.
Does anybody know if there is a fuse or breaker on the negative side of the back up alarm harness that I might have tripped or blown?
