The shocks are the same for both units, the springs and spring rates are different.My 13 900 single seat has different shocks than a 15 900 crew? If so are the crew front and rear shocks heavier duty than mine?
This information is incorrect.No idea on the rates, but if you look at them, a crew has springs that are the same size at all four corners, which look to be the same size as the rear on a regular cab 900, but the front springs are smaller in diameter.....that being said, a crew sets almost 3/4" lower stock, than a regular cab....
The rear A arms both upper and lower will work.Toxic-21 I have a friend wanting to sell me all his suspension and axles off a 15 900 crew will it all fit my 13 900 single seat?
Which part?This information is incorrect.
All of it except the part about the crew sitting 3/4 of an inch lower than the standard cab. I'm not positive on that one.Which part?
Slim, keep in mind the OEM shocks are poor at best, if I had a chance to get some extras cheap I would be all over them too.My 13 900 single seat has different shocks than a 15 900 crew? If so are the crew front and rear shocks heavier duty than mine?
May be interested in some parts if you decide to sell some.Yeah for the money a new set of shocks would be better I just thought if I got all of his suspension I would have spare parts for sale or for me he wants $500 for all suspension and LE rims and pxt tires not a bad deal.
Well I guess you know.......but my statement holds true for the Rangers around here.....and the about the 3/4" difference, its in the owners manual....All of it except the part about the crew sitting 3/4 of an inch lower than the standard cab. I'm not positive on that one.
Ok I'm listening, please explain.wfo is correct on the springs and if you want to lower your ranger then you would want to put on crew springs....
Right here you answered it yourself, shocks are same and as you stated the a-arms are the same.....The springs and spring rates are different, therefore a different ride height. If spring rates are different then free length doesn't equate. Pull a crew and xp side by side and take a look.The shocks are the same for both units, the springs and spring rates are different.
Spring free length is the same for both.
OK, you win!Right here you answered it yourself, shocks are same and as you stated the a-arms are the same.....The springs and spring rates are different, therefore a different ride height. If spring rates are different then free length doesn't equate. Pull a crew and xp side by side and take a look.
