I am in the middle of installing my roof seal kit and am having a little concern on where exactly the front rubber seal goes. Does it attach to the roof like the sides and rear or cage? The second question is where exactly does it get placed....I am assuming right across the honeycomb strip on the roof and not in the windshield to cage gap?
I finally removed the windshield so be able to get the top in place. The big rubber piece goes in the front. The the short pieces over the doors....then the long piece in the back.....I stuck mine to the top so if I want to go topless in the summer the gasket stays with the top. Be sure to have two Swartsanaggar type muscle heads there to help beat the top into submission and back into place...may God be with you.
· Administrator
As stated above, attach the weatherstripping to the top, not the rollcage. And with the weatherstripping installed, it makes it more difficult to install the roof.
Got er done today with seal, headliner and one of two Rigid dome lights mounted. Just need to order the second dome and wire the switches. I used Armor All on the front seal and roll cage. I fought with it for about 10 minutes but the Armor All really helped.
