Is there any reason why using an aftermarket fan blade and motor and putting them in the factory shroud would not work? I got 2 10" fans off of Amazon cheap and was going to mod the shroud to bolt one of them on it. That would be alot of cutting to do. So I just swaped the motors and bldes out. It seems to be working fine now but not sure when its 100* out side again. Only thing I see that might be a problem is that the blades are 10" and the shroud is maybe 11" wide. There is a small gap at the edge of the blades. Any advice on this would be great.
Oh btw my stock fan would not spin freely and one of the blades had an 1/4" crack in the leading edge. Was not going to put that back on.
